1990 Other Toyota Models oil leaks
1990 TOYOTA
156,000 MILES • 4 CYL • 2WD • MANUAL
KEVIN BARKER
My toyota pickup is leaking oil around the aluminum sleeves that surround the spark plugs. This engine has sort of a double cavity on the spark plug side and these aluminum tubes isolate the spark plug from this cavity. Why is this?
Aug 4, 2008 at 11:53 PM
KHLOW2008
  • 41,814 POSTS
Hi Kevin ,
The sleeves and rubber seal needs to be replaced after a certain period of time and when spark plugs are removed.
It is the designed thus so no other way around it.
Aug 18, 2008 at 9:34 AM
