mr2 mk2 clutch
TOYOTA MR2
CHAZ
the problem is when you hold the clutch down it losses presure as if it needs bleeding there are no fluide leaks and clamping the master off gives a much harder pedal
Mar 8, 2006 at 1:41 PM
FISHERMAN
  • 937 POSTS
sounds like your clutch cylinder (master cylinder) its by-passing the fluid. (leaking from inside the seals...)
Mar 8, 2006 at 8:14 PM
CHAZ
i cant see its the master due to the diffrence in pedal feel when its clamped off from the slave any other ideas
Mar 9, 2006 at 11:37 AM
