1992 Toyota MR2 timing belt
1992 TOYOTA MR2
171,000 MILES • 4 CYL • 2WD • MANUAL
VROOMR2
  • 4 POSTS
just replaced timing belt. i followed instructions on the manual and i also made sure that i was on tdc. when i started the car it sounded good then when i drove it its like loosing power and the car has no acceleration.
Jun 24, 2008 at 9:29 AM
DOCFIXIT
  • 18,828 POSTS
Did you turn engine over by hand a few times and recheck alignment? Sometimes you think you got it but due to the tenisioner and how belt was routed they get off a few teeth and she don't have no get up. Also did you check to see if any valves may have been bent can.t recall if this is an interference engine ore not. Let us know
Jun 24, 2008 at 9:46 AM
VROOMR2
  • 4 POSTS
yes i did rotate engine by hand, made 2 turns and it was still align. also that while in nuetral i step on the gas and it doesnt rev normal. rpm wont even reach 4000rpm
Jun 24, 2008 at 2:43 PM
VROOMR2
  • 4 POSTS
oh i forgot to mention the first time i installed the belt the car didnt start then i figured it wasnt align then redid it again and it started but with problems i have mentioned earlier.
Jun 24, 2008 at 9:10 PM
VROOMR2
  • 4 POSTS
it's non interference.
Jun 27, 2008 at 5:33 PM
DOCFIXIT
  • 18,828 POSTS
Lets go for basics check puel pressure and coil spark should be blue/white. Also put timing light rev does it advance 38 deg at 3000rpm.
let me know
Jun 28, 2008 at 10:01 AM
