1988 Toyota MR2 WINDOW LIFT MOTOR
1988 TOYOTA MR2
90,000 MILES • 4 CYL • 2WD • MANUAL
CARL STERLACHINI
HOW DO YOU REMOVE THE DRIVER SIDE WINDOW LIFT MOTOR.
Jul 3, 2010 at 11:13 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
The first step would be to gain access to the motor by removing the door panel. To do this, remove the inside handle bezel. Remove side view mirror cover and pry loose the retainer and remove the cover. Remove the door trim. Remove the 2 screws and inside pull handle. Remove the cap and 4 screws. Insert a screwdriver between the retainers and door trim to pry it loose. Disconnect power window connector. Now you should see the window motor. First raise the window and block it up or tape it up before removing the window regulator/motor. Remove the window mounting and regulator mounting bolts. Now the motor and regulator should come out.
Jul 8, 2010 at 3:06 PM
