Engine Mechanical problem
1985 Toyota MR2 4 cyl Two Wheel Drive Manual 130k miles
I am down to the last two possible problems with a fuel issue that I have been having. I have replaced the in tank fuel pump and a new in tank filter. EFI relay switch and fuses as well, along with a new external fuel filter. The only other thing that I can think of is the injectors or mass air flow sensor. How can I determine which of the two is actually the problem sense they both are outrageously expensive? Is there a test that a back yard mech. can do to find out which of the two it is?
Jun 23, 2008 at 3:03 PM
