1985 Toyota MR2 Clutch
1985 TOYOTA MR2
MONTIELDAN
1985 Toyota MR2 4 cyl Two Wheel Drive Manual
Okay, I noticed the clutch wasn't giving me as much resistance when I tried to shift. Before it would give me some resistance about halfway, but now it's not giving me any resistance at all. If I start it in neutral it won't shift into anything, however if I start it in first gear it will shake and wobble before it actually starts. As I shift when I drive around I hear a sort of click, but the car itself doesn't shake or grind when I drive it.
May 9, 2008 at 2:23 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would first be checking that the clutch hydraulics are ok, and that there are no leaks in the master or slave Cly. If fluid low repairer leaks and re bleed system start here first.
Mark (mhpautos)
May 9, 2008 at 5:57 AM
MONTIELDAN
Thanks a lot, I might have taken a while to replay with thanks, but thank you.
I replaced the cylinder, and bled the system and it drives even better than before.
Jun 21, 2008 at 2:26 PM
