2006 Toyota Matrix Maintenance service light
2006 TOYOTA MATRIX
45,000 MILES • 4 CYL • 2WD • AUTOMATIC
RVIERA5072
would like to know where or how to reset the maintenance service light. I usually do the oil changes and fluids check ups, etc...
Thank you
Ruben
Jun 25, 2009 at 8:40 PM
BMRFIXIT
  • 19,053 POSTS
NOTE:DO NOT depress brake pedal when selecting modes to avoid engine from starting.
On vehicles with smart key system, make sure smart key is in the vehicle. Pressing the "ENGINE START STOP" switch changes the ignition switch mode as follows:
First Time - ACC mode (accessories on).
Second Time - ON mode (power on and all accessories on).
Third Time - Power OFF mode (indicator light is off).
To reset MAINT reminder light after engine oil replacement, place smart key system in power OFF mode with odometer reading showing. Place smart key system in ON mode while holding down trip meter RESET button.
Hold trip meter RESET button down for at least 5 seconds. Odometer should indicate "000000" and MAINT reminder light goes out.
Jun 25, 2009 at 9:05 PM
