Toyota Land Cruiser 1990 FJ62, 3F, 182000kms
1990 TOYOTA LANDCRUISER
WARTHOG
The perfectly working A/C until recently, experiences
now weak air flow to cabin. The fan motor runs Ok. First I want to check air filter. Where is it?
Also A/C freezes and on long journeys must be switched off for some time. When restarted it is Ok and then freezes again. What can the cause?
Thanks
Oct 30, 2007 at 5:02 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You may already have solved this problem, but if not i will suggest some checks.
There is no cabin air filter in these Land Cruisers.
As to the performance of the A/C I would be checking the T.X valve (thermal expansion valve) if you can get the A/C pressures tested, this will aid your mechanic to pin point any fault.
Mark (mhpautos)
Dec 4, 2007 at 9:52 PM
