Hi, I have a 1979 Toyota FJ40 landcruiser with a 2F engine, mileage unknown exceeds mechanical limits. My brake pedal is extrememly hard to push and even when I do the vehicle does not slow down quickly. I brought it in and was told that the brake booster is bad. Problem is that this part is no longer available either as a new part or as a remanufactured part. What do you recommend as a suitable replacement if any? It is a dual diaphragm and I have disc up front and drums in the rear. I am thinking that I could perhaps use an entire master cylinder and booster from some other vehicle but I have no idea what might work. Since mine is no longer available I would like to switch it out for something a little newer and easier to get if I ever need to go this route again. Thanks for any help/advice you can give.
Bob
Bob
Feb 16, 2007 at 5:55 PM
