i need instructions on how to replace the antenna motor(operates intermittently) and mast .. can you help?
thank you!
Jun 11, 2008 at 3:51 PM
2CARPRO JACK
CERTIFIED EXPERT
Mitchell has nothing on the r&r procedure for the antennae assembly. If it is in the front fender,I would say that the inner fender liner has to come out to gain access to the motor.If you get a new one from Toyota it will have the mast already in it.Should just be a unbolt and bolt in deal
