1997 Toyota Landcruiser power antenna
1997 TOYOTA LANDCRUISER
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
D-HAYWARD
My antenna mast quit retracting back into the antenna motor. I can still hear the motor working but the antenna remains up. I removed the antenna mast and the plastic/nylon cord that retracts the antenna mast is broken off inside the motor unit. I tried to see if I could somehow pull out the remaining piece but I cannot see it inside. How do I remove the motor and/or replace the mast. I have the new mast with the long plastic/nylon cord. Any info would help.
Thanks, Dave.
Dec 10, 2008 at 4:53 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You have to remove the plastic inner guard cover to access the antenna, it is easy to remove but the fitting of a new mast is tricky, may be take out the antenna and give it to a mechanic to set up the new mast.
Mark (mhpautos)
Dec 10, 2008 at 6:17 PM
