Leak has been repaired twice (replacing lots of parts first time and yoke and pinion seal on second pass) but has come back again. What should be checked or tested to determine cause? Drive shaft? U-joint? Correct tolerances in case not done correctly before? Does it make sense to go back to same mechanic for a third pass?
Sep 30, 2010 at 4:53 PM
