is the Landcruiser front end set up the same as my 1985 toyota pickup? The entire front end pivots on a couple of large ball joints directly behind the brake assembly. The 85 pickup has a square fitting on the top of the ball joint and you just unscrew it and inject chassis lube-- is the Landcruiser set up the same way or are the ball joints lubricated with gear oil from the differential?
Nov 10, 2009 at 9:49 AM
