1987 Toyota Landcruiser timing gear cover and oil seal
1987 TOYOTA LANDCRUISER
218,000 MILES • 6 CYL • 4WD • MANUAL
SONOFAMOBILMAN
I am replacing the timing gear oil seal on the timing gear cover, along with the timing gear cover gasket. Do I need to replace the gasket on the plate behind the timing gears? and if so, how do I do that? It would seam like a lot of added work just to replace a another gasket that may not be leaking. Or is it somthing that should be done any way> since I am not exactly sure what to do in order to get the timing gears off of the front of the motor.
Jim
Nov 27, 2009 at 8:16 PM
DR LOOT
  • 2,311 POSTS
it should not be necessary to replace the gasket behind the timing gears, considering the cover should seal the whole timing gear system.
Nov 28, 2009 at 10:18 AM
