1984 Toyota Landcruiser Valve Rocker and Head bolt tension
1984 TOYOTA LANDCRUISER
4THOMSONS
Electrical problem
1984 Toyota Landcruiser 6 cyl Four Wheel Drive Manual
I am needing to know the best way to set my Valve Rocker and Head Bolt tension settings in my Landcruiser. Is this something I can do myself at home.
May 22, 2008 at 4:56 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
If the head has not been removed you should not touch the head bolts, you can do the valve clearances, but i need to know if it is a petrol or diesel engine, and before you attempt this, are you familiar with the method of re setting valve clearances?
Mark (mhpautos)
May 22, 2008 at 5:02 AM
4THOMSONS
It is a petrol engine and no I am not to familar with the Method of re setting valve clearences. I do have a mate that is a little and has offered to also help if needed.
May 22, 2008 at 5:15 AM
