1978 Toyota Landcruiser Sudden Overheating
1978 TOYOTA LANDCRUISER
22,000 MILES • 6 CYL • 4WD • MANUAL
ANZA
The temperature gauge indicates a hot engine. This occurs driving uphill and going slow in compund low. On a flat highway the engine temp is normal. The carb cooling fan comes on as well (rarely came on before). The cooling system is sound and there are no intake manifold leaks. There are no exhaust gasses in the radiator. The after market header exhaust pipes at #4 and #5 run 550F at idle. #6 at 350F and #1 at 275F. Timing is good.
Is it the head gasket even though there are no bubbles in the radiator?
Thanks
Aug 2, 2009 at 3:36 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
The viscus coupling fan is problem faulty and not drawing significant air at slow vehicle speeds, also have the radiator cleaned & flow tested and check the thermostat.
Mark (mhpautos)
Aug 2, 2009 at 7:48 PM
ANZA
Hello Team,
Thanks for the quick response.
The viscous coupling fan had been replaced and observed to come on at the appropriate time.
The thermostat has been replaced twice (OEM) with no change.
The radiator is a new 4 row aftermarket radiator. I installed an old 4 row radiator I had in storage that I had replaced in 1999 because it had a small leak. The old radiator worked the same as the new radiator i.e. no change on the temperature gauge.
I replaced the water pump because of a catastrophic failure. No change.
I tested for exhaust gasses at the radiator with the cap removed using a blue dye. No color change. Then I took the truck to a radiator shop that performed the same test. Again no color change. There are no bubbles in the top of the radiator or in the overflow tank with the cap installed. I torqued the head bolts to 90 ft/lbs – nothing moved and I checked the valve lash. Lash is good (I had adjusted the valves just 1000 miles ago).
There are no leaks in the intake manifold or from the manifold gasket. I checked with propane, carb cleaner, WD40, and smoke – all with the fan disconnected.
The temperature gauge sending unit was changed – no changes.
There is a sending unit for the carb cooling fan near the temperature gauge sending unit on the head as well. The carb cooling fan is coming on regularly. It rarely came on before. This observation supports that there is excess heat not being scrubbed away and it’s not a faulty temperature gauge.
An infrared thermometer tells me that the cooling system is working well. The temperature at the temperature sending unit gets as high as 199 F.
I’m guessing a blown head gasket, yet there are no obvious indicators that this is the problem other than a hotter engine. As a diagnostic tool, I put some Stop Leak in the radiator. This helped the symptoms. It quit running higher and higher on the temperature gauge at idle as it did before the Stop Leak. Now the gauge will stop (but still too high).
The water pump is working well. I installed an inline filter in the upper radiator hose – no deposits or clogging materials in the filter (1/16” square mesh). I have flushed the cooling system extensively, in reverse flow as well.
So uh, yeah. I’m about out of options. I don’t want to pull the head only to discover the problem was something else. The truck starts instantly, idles well, and accelerates well. On flat ground the truck runs at normal temperature. The fact that the climb on the temperature gauge was sudden and the carb cooling fan comes on might be a clue to this puzzle.
Thanks for your help. I hope a solution is near. Maybe it's running lean? How would I check this?
Dan
Aug 3, 2009 at 7:58 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You may need to have the radiator professionally cleaned & flow tested, as you can have a number of blocked cores and still have flow, flushing with a garden hose can give the impression that it is ok, but in fact it can be partially blocked, An engine running lean will run hot, this can be checked with a Co meter in a exhaust gas analyzer, most today are 5 gas and will give you plenty of information, re check the timing and valve clearances as well.
mark (mhpautos)
Aug 5, 2009 at 4:56 AM
