2005 Toyota Highlander the engine ID # ?
2005 TOYOTA HIGHLANDER
12,532 MILES • 6 CYL • AWD • AUTOMATIC
MIMHNGUYEN
  • 5 POSTS
Would please tell me how to get the Engine ID number
of my car ?
Feb 13, 2009 at 5:07 AM
BMRFIXIT
  • 19,053 POSTS
VIN # have in it every thing you should need this is a brake down sample most ive seen is 3.3L engines
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_198.jpg
Feb 13, 2009 at 5:20 AM
MIMHNGUYEN
  • 5 POSTS
hello BMRFIXIT
I had a Toyota Highlander limited 2005, The VIN # JTEEP21A650115807, I shiped the car to Vietnam , right now the car is inside the Container which I shiped a long with my belonging. Now in order me to do the clearance the car , I need the Engine ID Code( but the car is inside the container so Noway I can get to the container before it clearance. Is there any way you can help or susgest to get the engine ID code ? Do you think the Toyota dealer which I bought the car from they can find out by the VIN # in their system ?
I really need help otherwise my car will be ship back to the US but right now I am in Vietnam.
Thanks so much, your help would be very appreciated
Go through so much Troubles in Vietnam
Minhnguyen
Feb 13, 2009 at 7:21 PM
BMRFIXIT
  • 19,053 POSTS
i think running the vin can tell all you need on that truck
with out me running the vin I think the code you need is (3MZ-FE)
let me know if that help and if not I will try and call the dealer for you on Monday
its Saturday here know
Feb 13, 2009 at 10:19 PM
MIMHNGUYEN
  • 5 POSTS
Hi BMRFIXIT
I think this (3MZ-FE) is a Engine size # not the Engine ID Code
I really need the Engine ID Code, Please help me to call the Toyota dealer to find out for me, your Help is really deeply appreciated .
Thankyou so much for your times
Feb 14, 2009 at 8:33 AM
BMRFIXIT
  • 19,053 POSTS
you need engine searial # ?
Feb 14, 2009 at 12:53 PM
MIMHNGUYEN
  • 5 POSTS
Hi BMRFIXIT
Is the searial # under the hood which stamped on the side of the engine ? I need the number which stamped on the side of the engine( I am not sure that they call the engine id code or engine searial # ?) if that number they called the engine searial # then it the one I need it.
Wish you have a wonderful weekend
Feb 14, 2009 at 7:43 PM
BMRFIXIT
  • 19,053 POSTS
Its serial number I will try and call dealer for you on Monday and will let u know of the out come
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_201.jpg
Feb 14, 2009 at 9:51 PM
MIMHNGUYEN
  • 5 POSTS
Hi BMRFIXIT
Thankyou so much for your times , I am really appreciated your help. As shown on the picture you posted,the number stamped on the right side of the engine block (picture A) is the number I need.I am waitng for the out come on monday..
Again thanks millions
Feb 14, 2009 at 11:22 PM
BMRFIXIT
  • 19,053 POSTS
According to two-dealer parts department I called
They both said they have been using the VIN # as an engine serial #
Good luck and hope that helped
Feb 16, 2009 at 9:33 AM
