SERPENTINE BELT
2003 TOYOTA HIGHLANDER
JOHN MASTERS
I need a diagram to route the serpentine belt?
Jul 7, 2009 at 11:29 AM
MERLIN2021
  • 17,250 POSTS
Hello, Here is a diagrams below to show you the routing and a guide to walk you through the steps of changing it out.
https://www.2carpros.com/forum/automotive_pictures/62217_highlander_1.jpg
https://www.2carpros.com/articles/replace-serpentine-belt Please let us know if you need anything else to get the problem fixed.
Jul 7, 2009 at 11:37 AM
JOE KASHMER
what is the best way to change the outer belts? Alternator and the power steering belts.
Jul 29, 2019 at 3:00 PM (Merged)
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you please tell me if your model is just a Highlander or the limited. Also the engine size in liter.
JOE KASHMER
Highlander Limited 3.0 liter
IMPALASS
  • 3,112 POSTS
Hello –
Well the manual doesn’t show your information. That usually means they consider that basic enough to be performed by looking at it.
I will be more than happy to assist you if you can either take a several pics of the front part so I can see the belt routing or you can describe it.
From what you say…….you have 2 belts? One that goes to the crankshaft, alternator and power steering…..with no other pulleys in-between?
Then an inner belt that goes to the crankshaft, water pump, AC? Is this correct or am I missing something?
Do you have general auto mechanical knowledge?
