2001 Toyota Highlander cyl #2 misfire
2001 TOYOTA HIGHLANDER
TOMALBANY
Engine Performance problem
2001 Toyota Highlander 6 cyl All Wheel Drive Automatic
My engine is misfiring. OBD 2 scanner says cyl #2. I replaced the plug (iridium). Problem still exists. I switched the plug wire/coil with another cyl. Same problem (#2). I switched injectors arouind. Same thing (#2). Not a sludge engine. Pulled valve cover recently. Pretty clean. Frequent oil changes, although.... Within the past 20,000 mi (Approx. 2 yrs) have begun to burn unusually large amounts of oil. Especially during highway trips 65-75 mph. 300 mi rd trip, 1.5 qts burned each way!!! Also blue smoke cloud @ cold start-up. Burns little or none driving aroun town 30-40 mph, for 2-3-4 weeks. Waddaya think?
Oct 17, 2010 at 2:18 PM
Hi tomalbany, Welcome to 2carpros and TY for the donation
Check and test the compression for cylinder no. 2 and also the crankshaft position sensor-
Oct 17, 2010 at 2:26 PM
TOMALBANY
Based on the senerio, do you think burned valve or worse?
Oct 17, 2010 at 3:39 PM
Could be depends on the cylinder compression both dry and wet readings- or a cylinder leakage test
Oct 17, 2010 at 3:45 PM
