Error code 97(2). P0441 This error code was found from scan tool (Launch X431v).
May 29, 2019 at 5:01 AM
CERTIFIED EXPERT
Welcome to 2CarPros.
Code 97 should be the same as a P0441.
DTC P0441 Evaporative Emission Control System Incorrect Purge Flow
Is the check engine light staying on? Also, have you tested it with a typical OBD 2 scanner. I hate to ask this, but are you in the US? It makes a difference.
May 29, 2019 at 7:33 PM
ATHYCX PYRO
MEMBER
check engine light no came up..
May 30, 2019 at 9:32 PM
ATHYCX PYRO
MEMBER
I'm from Malaysia. In Malaysia we called it Toyota Hilux SR, engine 2KD-FTV.
May 30, 2019 at 9:35 PM
ATHYCX PYRO
MEMBER
what is evaporative emission control system and where it located?
May 30, 2019 at 9:38 PM
ATHYCX PYRO
MEMBER
it's a diesel engine not gasoline.
May 30, 2019 at 9:44 PM
CERTIFIED EXPERT
Welcome back:
That makes a big difference. I was thinking it was a gas engine. I honestly don't have access to what that code is for. When I crossed code 97, I came up with an emission issue., but that won't relate to this vehicle.
Is it running properly?
May 31, 2019 at 6:06 PM
ATHYCX PYRO
MEMBER
Easy start but stall and stop suddenly in second.
May 31, 2019 at 8:02 PM
ATHYCX PYRO
MEMBER
how about fault code P0200.
Image (Click to enlarge)
May 31, 2019 at 8:03 PM
CERTIFIED EXPERT
Welcome back:
The P0200 is related to a fuel injection malfunction.
