2001 Toyota Echo a/c noise
2001 TOYOTA ECHO
50,138 MILES • 4 CYL • 2WD • AUTOMATIC
CHARLIEBROWN5
I'm hearing the a/c fan turn in and running while I'm parked, stopped @ a light and stopped in traffic. I first noticed the noise 2 yrs. ago just slightly and now its louder than before. There's no noise when the "fan" is on without the a/c on. Then there's a slight vibration happening when the a/c itself is turned on and running.
The a/c noise starts off like this: I turn on a/c and a "squeky" like noise begins followed by hearing the fan turning on and running and then slight vibration. My a/c does work so I do get cool (not cold) air inside cab. When I bought car from original owners back in 10/2004, I took it to Costco to get brand new tires, checked the alinment-good. Then to Maui Toyota dealership to check on
a/c cause I thouught it wasn't cold enough-was cool. They said everything is fine and that the slight vibration coming from the a/c unit was normal. Do I have a big problem brewing???
May 26, 2008 at 5:17 PM
The symptoms that you described sounds like the compressor is on its way out-you have a leak somewhere and the pag oil is running dry and could lock up the compressor been here before Brada-
May 26, 2008 at 5:29 PM
CHARLIEBROWN5
What's "pag oil"? Thanks!
May 26, 2008 at 8:21 PM
The oil in the compressor called Pag Oil-
May 27, 2008 at 6:39 AM
RUHL639
I've been having the same problem. My 2001 Echo started to make a loud screeching noise when I ran the A/C and was stopped. It got progressively worse to where it screeched even when I ran the fan only. I tried many tings including resin on belt, replacing belts, getting A/C check, etc. and nothing worked and no one had any ideas. Then a strange thing happened, I reached 95,000 miles and changed the spark plugs, and almost all the noises went away. I still get a little bit of noise when I run the A/C while stopped but not all the time.
Dec 29, 2010 at 9:50 PM
