So this problem just started out of nowhere...i mean i didn't touch the car and it just happen...except it was also the day i pulled out the EFI fuse that same day. the fuse is fine and place back in. heres whats goin on. it has good compression and the same compression readings before this occured. i've recently changed the spark plugs already before this. its certainly not the cables although i will be replacing it as soon as autozone can fine me a set that fits my car. secondly i feel that the problem is somewhere in my fourth cylinder. when i pull out the 4th sparkplugg cable nothing changes in the vibration. if i pull out any other cable it shakes even more. also the tip of the sparkplug in the 4th cylinder for some reason has light carbon build up whereas the others do not.
I would guess its the fuel injectors...i've only use fuel injector cleaners several times. does nothing. yet i don't understand how a "clogged" injector would cause my engine to shake. the only other thing i was worried about is whether or not i have the wrong gap for my spark plugs. i think kragens may have gave me a .044 when my car needs a .043. so far i could have checked these things just that i didn't have a guage on me. i'll be checking that anyways not sure if itll help.
If the fuel injectors can cause shaking...how and why? i just trying to decide if i should take the injectors apart and super clean them or replace and what not.
Feb 26, 2007 at 9:52 PM
