The engine type is 5M-GE and the color of the spark was bluish (had white color to it...sure it is more blue than orange).
When I pulled the plugs (all of them) to test them for sparks I took a look at the piston heads. From what I can see and touch with my screwdriver, there is carbon buildup. No signs of coolant.
Here is something I found: After drying out plugs and chamber overnight from excess gas...put them back in...crank...car started for few seconds and then shuts off. I then cranked the engine and stepped on the gas peddle and the car kicked over but ran rough until I let go the peddle (then it shuts off). White smoke was coming out of the tailpipe. I could smell the gas also. Now the car is back to original state again. Just cranking. I think the the fuel is going to keep on injecting no matter if the car starts or not. Now it probably is filled with excess gas again.
I need to check for the jumped timing like you mentioned because that could be a significant factor. To do it, do I turn the engine manually and set the 1st piston to the top where the pressure (air) releases and then check to see the location of the rotor?
I am going to check the compression today and leave the fuel pressure out for now as I don't have the tool for it. That way, I would be able to eliminate the culprit down to a bad engine (whether it be of piston or valves), bad computer (since it is an electronic fuel injection system), injectors not closing a valve or something, or bad fuel pump.
May 26, 2020 at 8:09 PM
(Merged)
