1994 Toyota Cressida Engine runs rough in the morning
1994 TOYOTA CRESSIDA
138,000 MILES • V12 • FWD • AUTOMATIC
PAUL LEE
My car engine runs rough in the morning.The rpm is higher than normal.The engine sounds louder than normal. However, after running the car for 15 to 20 minutes the car is smooth again. the rpm becomes normal. I ve changed the spark plus, plug cables, alternator and battery but the problem is still there each morning.
Mar 3, 2010 at 9:46 PM
Engine running rough or misfiring can be cause by the following-inspect and test all the following below:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Idle air control valve.
11.Throttle position sensor.
Apr 20, 2010 at 5:48 PM
