1988 Toyota Cressida ENGINE VIBRATES
1988 TOYOTA CRESSIDA
ROSSENO
Engine Performance problem
1988 Toyota Cressida 6 cyl Two Wheel Drive Manual 155 58 miles
I HAVE CRESSIDA'88 2000 CC. THE IGNITION SYSTEM USING CARBURATOR (THE ORIGINAL WAS INJECTION) WHEN I GOT IT. THE SELLER HAD CHANGED THE IGNITION SYSTEM. CARBURATOR USING SUZUKY CARRY 1000 - 1300 CC. MY QUESTION IS: THE TOP SPEED IS 115 KM/HR AND VIBRATES AT THIS SPEED. I FEEL UNCOMFORT. DOES IT CAUSED BY THE IGNITION CHANGING? OR BY ANOTHER ELSE? AT SPEED BELOW 115 KM/HR I FEEL COMFORT, NO VIBRATION.
THANK YOU
May 4, 2009 at 4:01 AM
MMPRINCE4000
  • 8,548 POSTS
Most likely you have an issue with wheel balance or alignment. Take to alignment shop and have it checked.
May 4, 2009 at 6:44 AM
EXTRUDEDCOW
  • 27 POSTS
I can say from experience that at least a 1984 toyota cressida can hit 108 mph without shaking. That someone put a carb on a cressida is just strange. However, since the problem seems to not be linked to engine speed, this change is probably not the culprit.
May 9, 2009 at 7:41 PM
MMPRINCE4000
  • 8,548 POSTS
The carb thing is wierd, but some people would rather not spend the money to get the FI working, so they go carb.
May 10, 2009 at 7:18 AM
