replaceing the oil pan gasket
TOYOTA COROLLA
TERENCE
toyota corolla 2003 1.8 liter eng. 120,000 Kl.
Do I have to remove the cross-member from below the oil pan to be able to replace the leaking gasket?
Thank you for your help.
Terence :)
Jun 10, 2007 at 2:49 PM
WAY7158
It makes the job a whole lot easie rto do, but you can loosen the bolts enough and lower the crossmember a bit to get a socket or wrench in the area. Have lots of patience with the latter suggestion.
Aug 29, 2007 at 7:45 PM
