radiator cooling fans. Car running hot.
TOYOTA COROLLA
LEONIVETTE
I just got a 1998 toyota corolla 1.8 L . It is running hot. The fans are not coming on. I did some research and tried the air conditioning and the fans come on with the air on. After more research I disconnected the switch on the themostat housing and the fans came on without the air being on so I assumed the switch was bad and replaced it, $85.00 It did not take care of the problem fans still do not work. I have since checked the top and bottom radiator hoses while it is running and both are hot.
Any Ideas ? E-mail - [email protected]
Thanks.......
Apr 5, 2007 at 5:47 PM
[quote:618f0b51ca="leonivette"]I just got a 1998 toyota corolla 1.8 L . It is running hot. The fans are not coming on. I did some research and tried the air conditioning and the fans come on with the air on. After more research I disconnected the switch on the themostat housing and the fans came on without the air being on so I assumed the switch was bad and replaced it, $85.00 It did not take care of the problem fans still do not work. I have since checked the top and bottom radiator hoses while it is running and both are hot.
Thanks.......[/quote:618f0b51ca]
Check the 15amp ECU fuse and R1 radiator fan relay and water temp. switch
Apr 6, 2007 at 5:41 AM
LEONIVETTE
[quote:0f570e5c73="rasmataz"][quote:0f570e5c73="leonivette"]I just got a 1998 toyota corolla 1.8 L . It is running hot. The fans are not coming on. I did some research and tried the air conditioning and the fans come on with the air on. After more research I disconnected the switch on the themostat housing and the fans came on without the air being on so I assumed the switch was bad and replaced it, $85.00 It did not take care of the problem fans still do not work. I have since checked the top and bottom radiator hoses while it is running and both are hot.
Thanks.......[/quote:0f570e5c73]
Check the 15amp ECU fuse and R1 radiator fan relay and water temp. switch[/quote:0f570e5c73]
Hi Rasmataz :)
Thanks for responding. I have already changed the switch, $85.00 Next, I have my toyota book showing fuses ;
Engine compartment - 1. A/C 7.5 amp: air conditioning,electric cooling fan.
Engine compartment - 2. CDS 30 amp: electric cooling fan.
instrument panel - 3. ECU-IG 10 amp: starting system,electric cooling fan, automatic transmission shift lock system,anti lock brakes, cruise control.
Engine compartment - 4. RDI 30 amp: electric cooling fan.
Is there a way to test the relay you mentioned ?
Thanks, [email protected]
Apr 6, 2007 at 6:58 PM
[quote:a421559f22="leonivette"][quote:a421559f22="rasmataz"][quote:a421559f22="leonivette"]I just got a 1998 toyota corolla 1.8 L . It is running hot. The fans are not coming on. I did some research and tried the air conditioning and the fans come on with the air on. After more research I disconnected the switch on the themostat housing and the fans came on without the air being on so I assumed the switch was bad and replaced it, $85.00 It did not take care of the problem fans still do not work. I have since checked the top and bottom radiator hoses while it is running and both are hot.
Thanks.......[/quote:a421559f22]
Yup! there's a diagram on it that shows you the switch and coil side-at the switch side you should have no continuity and at the coil-you should have continuity
Connect power to one side of the coil and the other side to ground-now the switch should have continuity-meaning it should transfer power to components when it has power on one side.
That's aLL for now-you're breaking my brain and tommorrow is roger rabbit's day and I need to complete my doctor's call at other forums in this site.
Catch you later-keep posting am watching
Happy Easter
Check the 15amp ECU fuse and R1 radiator fan relay and water temp. switch[/quote:a421559f22]
Hi Rasmataz :)
Thanks, [email protected][/quote:a421559f22]
I messed-up look above how totest the relay
Apr 7, 2007 at 1:41 AM
