gas leakage, oil to use
TOYOTA COROLLA
ARCOBALENO
Hi, my toyota corolla 1995,(1.6L engine), 260000, has a gas leakage (only when I fill my tank ful) about 5 inches from my left rear wheel. I changed my gas tank, and next day again leakage.Now what to do?
Also I would like to change from Castrol GTX to Castrol High Mileage, is that good idea?Or even better can you recommend some god oil for my case?And please what do you think about Lucas oil supplements
Thanks a lot!
Apr 12, 2006 at 7:55 PM
LOSONE
  • 1,616 POSTS
The leak is probabbly the filler hose connection or the clamp for the hose to the tank may be loose.
GTX high mileage oil is excellent. I use it but make sure it is 10W30 and no thicker. Good luck
Apr 18, 2006 at 5:51 PM
