Error code P0505
TOYOTA COROLLA
AGLABRAT
  • 4 POSTS
Automatic 1.8 L four cylinder 173,000 miles. Changed idle control valve. Check engine light went off, but came back on about an hour later. Have rechecked codes. Still have P0505 code. When cold the car hesitates badly when taking off. Once warm it runs good.
Oct 17, 2007 at 9:17 PM
This codes is telling us the computer cannot control the engine idle which can be caused by a dirty throttle bore or a vacuum leak.
Here are two guide that will help us fix the problem:
and
Cheers
Oct 18, 2007 at 5:12 AM
AGLABRAT
  • 4 POSTS
I believe the P0171 is because while running at idle I removed each injector electrical connection one at a time than replaced it before taking the next one off to see if one would sound different.
Thanks for any help.
Oct 19, 2007 at 9:44 AM
KENN
  • 0 POST
I had this problem the throttle bore was gunked up bad. once I cleaned it the problem went away.
Apr 24, 2018 at 12:45 PM
