Dim Headlight
TOYOTA COROLLA
MATHINEER
I have a dim headlamp in my 1997 toyota corolla. I replaced the bulb, but it's still dim. I measured the voltage across the bulb and it is less than 5V. The other bulb is fine, and the battery is holding over 12V under these conditions. Obviously, the 7 or so volts is being dropped somewhere else in the system. I don't have a wiring diagram handy. Any ideas where to look for the problem?
Thanks in advance!
May 8, 2007 at 1:04 PM
MIKE H R
  • 3,094 POSTS
check the ground on the light
May 8, 2007 at 6:17 PM
