Corolla Error Code P0505
TOYOTA COROLLA
AGLABRAT
  • 4 POSTS
Had error code P0505 on 2000 Toyota Corolla Automatic 1.8 L 4 Cyl 173000. Changed Idle Control Valve. Check Engine Light went off, but came back on about an hour later. Have rechecked Codes. Still have P0505 code and P0171.
I believe the P0171 is because while running at idle I removed each injector electrical connection one at a time than replaced it before taking the next one off to see if one would sound different.
When cold the car hesitates badly when taking off. Once warm it runs good.
Thanks for any help
Oct 22, 2007 at 1:39 PM
TENTETH
  • 5 POSTS
System Lean.
I had this code recently as well. Mine turned out to be the Oxygen sensor before the cat, directly under the manifold was bad.
for 93-02 corollas Resistance should be 11-17 ohms.
For 2004 it should be 14.7-17
Hope this helps.
Oct 23, 2007 at 6:26 PM
AGLABRAT
  • 4 POSTS
Which code did you have the P0505 or the P0171
Oct 28, 2007 at 9:01 PM
