2010 Toyota Corolla Rims
2010 TOYOTA COROLLA
KNAYAN
Tires and Wheels problem
2010 Toyota Corolla 4 cyl Two Wheel Drive Automatic
I have 2010 Corolla CE. I also have winter tires mounted on rims which were used on 2009 Elantra Comfort. Can I use this set on 2010 Corolla CE. Tire size seems to be the same size 195/65 R15 but I don't know whether rims are same. Please advise.
Nov 21, 2009 at 12:30 PM
MMPRINCE4000
  • 8,548 POSTS
There is rim size, width and offset. Make sure the offset is the same on both rims.
Of course, you know that if you experience ANY problems with the rear end, Toyota will void the warranty due to non-approved rims.
Nov 22, 2009 at 7:30 AM
KNAYAN
Thanks for the kind response. Could you please claify what is meant by offset?
[quote:fac7b66e6d="mmprince4000"]There is rim size, width and offset. Make sure the offset is the same on both rims.
Of course, you know that if you experience ANY problems with the rear end, Toyota will void the warranty due to non-approved rims.[/quote:fac7b66e6d]
Nov 22, 2009 at 9:35 AM
MMPRINCE4000
  • 8,548 POSTS
The distance in mm that the wheel goes in or out on the hub.
Nov 23, 2009 at 7:08 AM
