2007 Toyota Corolla no spark,inj.pulse, no fuel pump
2007 TOYOTA COROLLA
40,000 MILES • 4 CYL • FWD • AUTOMATIC
ACE2425
car had been running fine. filled with fuel, drove 30 mile and parked for about 30 min. started backed up about 4 feet , died, after a number of tries restarted as long as accel. petal was depressed 50%. has not restarted since. has no fuel pump, no spark, no inj. pulse. think have check all fuses. fuel pump will run if feed red/blk wire at pump module. please any help will be a big help. thank you
Mar 18, 2009 at 8:02 PM
Check the following EFI fuse, EFI relay, Circuit opening relay and ignition switch.
Mar 19, 2009 at 5:00 AM
