2006 Toyota Corolla serpintone belt change
2006 TOYOTA COROLLA
70,000 MILES • 4 CYL • FWD • AUTOMATIC
PISTOLGRIP
I do not see a place for a breaker bar to releave pressure off an idler pulley, or the adjustment to one of the other pulleys to allow for the belt change. Where do I find the adjusment pulley so to change the serpintine belt?
May 29, 2010 at 11:23 AM
KHLOW2008
  • 41,814 POSTS
Hi pistolgrip, Thank you for the donationo. On the autotensioner there is a bolt head (19 mm) that you can use as leverage to loosen the tensioner to remove the belt. Turn it clockwise to release the tension.
https://www.2carpros.com/forum/automotive_pictures/192750_SerpentineBelt06CorollaFig05_1.jpg
May 29, 2010 at 1:46 PM
