I bought a used Toyota corolla 3 months back. On test drive i found the 1NZ-FE engines shakes a bit in neutral gear. Then the seller told me that the spark plugs probably warn out which he replaced and the engine shaking problem was gone.
After 3 months i m again experiencing similar shaking or vibration of engine on neutral position.
Should I just replace the spark plugs or check other parts for this problem?
What type of spark plugs are suitable for my car?
I ran only 2,500 km after i bought it. The car runs on both octane and natural gas. So far the car is running well.
I would appreciate a reply from u with the solution.
Oct 4, 2009 at 5:23 AM
