Windshield washer motor location
2004 TOYOTA COROLLA
95,000 MILES • 4 CYL • FWD • AUTOMATIC
PHIL OWENS
My wipers work but the washer fluid won't dispense. I have replaced the fuse. Would I need to replace a motor or a pump?
Jan 6, 2010 at 4:08 PM
MMPRINCE4000
  • 8,548 POSTS
It sounds like the pump motor is bad which is common here are the instructions on how to replace the pump motor in the diagrams below. (F5) Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Jan 8, 2010 at 8:09 AM
PHIL_SCOTT
How do I change the washer motor/pump
Apr 27, 2020 at 12:06 PM (Merged)
MHPAUTOS
  • 31,937 POSTS
Hi there,
Remove the washer bottle and the pump is located at the base, its fitted into a rubber seal ring, it will come out fairly easily, (or it should)
Mark (mhpautos)
DAZMAZ77
We just got a second hand 1993 Toyota Corolla Seca CSI Limited. There was some problems with the electricals & we got those fixed. Now the rear wiper wont spray & the pump has already been replaced.
Can anybody help us as to what to do?
Apr 27, 2020 at 12:07 PM (Merged)
KHLOW2008
  • 41,814 POSTS
First thing to do is to check if the motor is buzzing when activated. That could mean the motor is working but water is not getting sprayed due to clogging of lines or leakages between motor and nozzle.
