2004 Toyota Corolla The Middle brake light is not working.
2004 TOYOTA COROLLA
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
MAXSEPOWER
Hello, the middle brake light is not working I replaced the light bulb. not sure what else to check.
Thanks
updated 3/12/09
I am super impressed with the speed and the exact description of the wire
and location of the connector. just a silly question how would i know the
8/9 ?? i am sorry i didn't get that one.
Mar 11, 2009 at 7:58 PM
Do a continuity test on the green and white wire between the bulb socket and the junction connector 8/9 at left side of luggage compartment
https://www.2carpros.com/forum/automotive_pictures/12900_high_mount_light_1.jpg
Mar 11, 2009 at 8:21 PM
MAXSEPOWER
i am not sure which is 8/9 can you give me more details? if it checks ok then what?
Mar 11, 2009 at 9:40 PM
The bottom brake lights are working-the lights are all powered from the junction connector in the luggage compartment. If this junction connector is okay the light should come on-check it and get back with some results
Mar 11, 2009 at 10:40 PM
Thanks
updated 3/12/09
The no. 8/9 terminal is the junction connector the brake light circuit splits from here to the brake lights. I assumed that you're refering the middle light as the high mount light -correct
Check the green and white wire on the middle brake light socket for power - do you have power if so the ground wire white and black is open
Mar 12, 2009 at 5:57 PM
MAXSEPOWER
The connector under the rear deck was unplugged.
Mar 16, 2009 at 7:35 AM
