VIN #2T1BR32E85C416304
Showing codes PO441/455/456 & pending codes PO441/455. Having trouble narrowing down where the problem is, below is the freeze frame data;
DTC CAUSE: PO455
THROTTLE POSITION: 19.2
ENGINE RPM) 0
LOAD VALUE) 0%
AIR FLOW RATE) 0.50 GR/SEC
COOLANT TEMP) 87 DEG
INTAKE AIR TEMP) 82 DEG
IGN. TIMING ADV) 5.0 DEG
SHORT TERM FUEL TRIM) 0%
LONG TERM FUEL TRIM ) 6.2%
S/T FUEL TRIM 3) -100.6%
L/T FUEL TRIM 3) -100.6%
FUEL SYSTEM 1) OPEN
FUEL SYSTEM 2) NA
L/T FUEL TRIM 3)
DTC CAUSE: PO455
ENGINE RPM) 0
LOAD VALUE) 0%
FUEL SYSTEM 1) OPEN
FUEL SYSTEM 2) NA
L/T FUEL TRIM 3)
Jun 2, 2009 at 8:34 PM
