2003 Toyota Corolla replace water pump
2003 TOYOTA COROLLA
DRHODES1953
Engine Mechanical problem
2003 Toyota Corolla 4 cyl All Wheel Drive 180000 miles
how to repalce water pump 03 Toyota Corolla
Mar 11, 2009 at 11:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Remove engine under cover RH Drain coolant Remove fan and alternator drive belt Remove alternator assembly by disconnecting the wire clamp from the wire clip on the rectifier end fram. Then remove the rubber cap and nut, disconnect the alternator wire. Next disconnect the alternator connector and remove the 2 bolts and the alternator. Remove the water pump assembly. (when installing replace O-ring on timing chain cover with new one and torque water pump bolts to specs below.) Install alternator assembly (torque 12 mm bolts to 25Nm and 14mm bolts to 54 Nm) Add coolant Check for engine coolant leaks. WATER PUMP BOLTS TORQUE SPECS BOLTS A = 9 Nm BOLTS B = 11 Nm
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_311.jpg
Thanks for using 2CarPros.com!
Jul 27, 2020 at 4:51 PM
