2003 Toyota Corolla rear hub assembly stuck-can't remove
2003 TOYOTA COROLLA
67,000 MILES • 4 CYL • FWD • AUTOMATIC
CARGO
After removing the four rear hub assembly bolts on my 2003 Corolla, the assembly still will not come off. Tapping with a hammer front and rear and applying penetrating oil doesn't seem to help. I am attempting to replace the hub assembly because of a bad bearing, ie I don't mind damaging the old assembly. What can I do to remove this stubborn hub?
Sep 15, 2009 at 8:50 PM
MMPRINCE4000
  • 8,548 POSTS
Apply heat to knuckle (propane torch), which will cause it to expand and the assy should come out.
Sep 16, 2009 at 8:15 AM
JOHNOCHOA
Hi, how did you remove the Hub at the end? I'm having the same problem.
Thanks
[quote:953c9cfb70="Cargo"]Suspension problem
2003 Toyota Corolla 4 cyl Front Wheel Drive Automatic 67000 miles
After removing the four rear hub assembly bolts on my 2003 Corolla, the assembly still will not come off. Tapping with a hammer front and rear and applying penetrating oil doesn't seem to help. I am attempting to replace the hub assembly because of a bad bearing, ie I don't mind damaging the old assembly. What can I do to remove this stubborn hub?[/quote:953c9cfb70]
Dec 27, 2009 at 12:15 PM
