Engine Mechanical problem 4 cyl Front Wheel Drive Automatic 114,00 miles
You have helped me solve problems with my vehicles. Now I need your help to solve a problem with a friend's vehicle.He is short on funds, knows nothing about cars, so I'm hoping I can fix it for him. His engine light came on and with my scan tool, the code P0446 was listed as the causative factor. I found out that the P0446 code corresponds to the evaporation emission control system vent control circuit malfunction. A person told me that this code relates to the canister shut valve and that I should replace the canister as well.I went to a local Toyota dealer and the most information I could obtain from them is that four different valves that relate to this code; however, one is the canister assembly that has the shut valve. I believe that I have located the canister by the fuel tank. I would appreciate any information (and diagrams as he does not have any repair manuals) you can give me so that I can repair his Toyota
The car is a Corolla CE. The only thing written on the engine is 16V VVT-I. I cannot find anything that lists the engine displacement. I hope this is enough information.
Dec 18, 2009 at 10:12 PM
