2002 Toyota Corolla No low beams
2002 TOYOTA COROLLA
RONE06
Electrical problem
2002 Toyota Corolla Front Wheel Drive Automatic 110000 miles
Both low beams (headlights) are not working but the High beams do. I have checked the fuses and they check good with a volt meter while installed. I could feel the relay energizing when I would pull it out and then reinstall it I could also hear the change of state in the relay. What would you suggest I check next? Is it possible the switch has gone bad in the low beam position? I am thinking it is something common between both right and left headlights Any help?
Thanks
Dec 9, 2009 at 11:21 PM
Check main fuse 40amp and head relay
Dec 9, 2009 at 11:50 PM
