2002 Toyota Corolla Car vibrates or rattle
2002 TOYOTA COROLLA
126,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOMFRA
Hello expert,
The car rattle and sounds as if it will loose up
When I drive over uneven or rough surface.
Regards
Jan 12, 2009 at 6:38 AM
MMPRINCE4000
  • 8,548 POSTS
Have all the suspension components inspected, ball joints, control arms, bearings, struts for loose or missing bolts.
Inspect motor mounts, exhaust system, for loose components. Also check brake components, calipers, pads etc.
You will most likely find a loose component or bolt that has worked loose or fallen out.
Jan 12, 2009 at 9:21 AM
