2001 Toyota Corolla clicking engine, loss of oil, dark? oil
2001 TOYOTA COROLLA
205,000 MILES • 4 CYL • FWD • AUTOMATIC
KLYNCH1969
I have been noticing an increasing amount of engine clicking in the last 20,000 miles. I notice it most when decelerating from 70mph (most likely other speeds also, but not that I can recall at the moment.)
The engine has also been loosing oil, perhaps a quart a week. and the oil when I check it is dark. I try to get the oil changed every 3000 because of the high miles.
Where should I get it checked at? (major store chains)
What type of checking should be done?
And what repair recommendations should I be suspicious of?
I just had the timing belt (major cracking) and front axle replaced (broken).
Thanks
May 28, 2010 at 7:56 AM
MMPRINCE4000
  • 8,548 POSTS
If this is a U.S. bulit Corolla it has a timing chain, not a belt. Toyota switched from belts to chains in 1999 , I believe.
If using that much oil, it is either leaking it or burning it.
Have shop check for oil leaks first. Use a local ASE shop, stay away from chains.
May 29, 2010 at 8:47 AM
