2001 Toyota Corolla Cleaning MAF sensor
2001 TOYOTA COROLLA
ELADD
  • 4 POSTS
Engine Mechanical problem
2001 Toyota Corolla 100k miles
Can spray brake cleaner (BrakLeen) be used to clean MAF sensors?
May 23, 2009 at 12:53 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Do not ues it harmful to plastics and electronics. Go to Wal-Mart @$4 Maf cleaner
Thanks for donate
May 23, 2009 at 1:20 PM
ELADD
  • 4 POSTS
Thanks for the info.
May 23, 2009 at 1:30 PM
DOCFIXIT
  • 18,828 POSTS
Your welcome need to clean MAF maintence or got a code?
May 23, 2009 at 1:36 PM
ELADD
  • 4 POSTS
Heard this code may result from dirty/faulty MAF sensor. So I decided to start simple and clean MAF. But I need to buy cleaner first. AFter that, I planned to check for vac. leaks. However, I'd heard elsewhere in this site that vac. leaks usually cause too rich conditions, not too lean. Should I skip checking for vac. leaks and move on to fuel delivery checks. I assume it can't be the O2 sensor - if so, I'd be getting an O2 code, right? Thanks for your time.
May 23, 2009 at 2:01 PM
DOCFIXIT
  • 18,828 POSTS
Clean MAF first but could you post the code in P0xxx format will advise
May 23, 2009 at 2:12 PM
