1999 Toyota Corolla strut leaking
1999 TOYOTA COROLLA
130,000 MILES • 4 CYL • 4WD • AUTOMATIC
JALJOSHI
aaa recomemded strut leaking all to change all four
I do not find leak on the parking area in the garage
as it is very expensive matter can u suggest some solution and if not changed what will happen kindly
advise and what is the cost you cna suggest for
parts and labour
thanks
J.D
Sep 10, 2009 at 9:34 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
There is not enough oil in these struts to leak and fall to the ground, if left you will experience stability problems along with tyre wear front struts will also effect breaking & steering stability, you will have to contact your local suspension dealer for prices as i am in Australia any my pricing will not be any good to you.
mark (mhpautos)
Sep 11, 2009 at 1:18 AM
