1999 Toyota Corolla question on dealer diagnosis
1999 TOYOTA COROLLA
SUDHURAO
1999 Toyota Corolla 4 cyl Two Wheel Drive
My car started making a tuck,tuck,tuck kind of noise mainly when driving at low speed recently. Sometimes, there's no noise for days, but when it happens, it seems to come from driver side front.
I got it diagnosed from a dealer service shop, and the diagnosis was that the front wheel bearings are the most likely cause. Also, I was pointed to some cracks on the ends (ends in the middle and not the end near the wheels) of the control arms (front). To change the front control arms and bearings the quote is around $1500 including labor. Is this a reasonable estimate?
Also, on a separate quote for the weakend struts, the estimate is about $1800. The car's worth $4000 and I'm really confused as to what I should do. Pl help. Thanks.
Apr 7, 2008 at 4:43 PM
MMPRINCE4000
  • 8,548 POSTS
Unless you can do the work yourself, you can shop around at local repair shops for a better price.
Some shops will install used parts, but the warranty is limited to replacement (additional labor) of the part.
Apr 8, 2008 at 5:28 AM
SUDHURAO
Can you pl tell how many hours of labor am I looking at for these changes:
1. Replace front left wheel bearings
2. Replace front arm hubs
Thanks.
Apr 8, 2008 at 2:08 PM
MMPRINCE4000
  • 8,548 POSTS
I would estimate no more than 8 hours.
Apr 9, 2008 at 7:58 AM
2CARPRO JACK
  • 11,533 POSTS
Both front wheel bearings- 3.6 hrs
3.1 hrs for both lower control arms
Apr 9, 2008 at 1:45 PM
