Check the Idle Air Control valve, they get dirty and can get stuck. Also check the EGR valve, they are not supposed to operate at idle/slow speed, if they open at idle, they will generally kill the engine.
Also make sure the torque convertor clutch is working properly, they engauge at 40-45mph, so you should feel the rpm's go up slightly when decelerating from 55 to 40-45, If not the TCC will kill the engine.
You can feel the TCC engauge when accelerating (smoothly) at 40-45mph. It will shift into high gear then you will feel a small "bump" when it locks up, you should also feel it disengage.
Jan 22, 2021 at 10:56 AM
(Merged)
