1999 Toyota Corolla battery fix
1999 TOYOTA COROLLA
STETSUNP
Shakes or Wobbles problem
1999 Toyota Corolla 4 cyl Front Wheel Drive Automatic 114k miles
Hi, my car didn't pass a car test because a battery was not fixed properly (shakes/wobbles). could you give an idea how it should be fixed correctly. if you have any pictures - it would be fantastic. Thanks in advance.
Feb 19, 2009 at 3:24 PM
You probably need a battery hold down to hold battery in place-you sure its the correct size battery for it.
Feb 19, 2009 at 3:29 PM
MMPRINCE4000
  • 8,548 POSTS
Most Toyota's use a bracket that spans the battery and is held down on front by bolt on frame and in rear by rod with hook on one end.
Buy a factory replacement from Toyota, or a generic one from most autoparts stores.
It is important that the battery is secure, if it moved and the + came in contact with any metal, it could do severe damage to electrical system.
Feb 20, 2009 at 8:03 AM
