1998 Toyota Corolla Suspect timing chain rattle
1998 TOYOTA COROLLA
15,900 MILES • 4 CYL • FWD • MANUAL
7A6B9C
98 corolla. 1zz motor 159k. Engine rattle at idle- intermittent. Not the serp tensioner. Removed valve cover and noticed chain loose/slack between cam gears. Turned motor to topdeadcenter and removed and reloaded and reinstalled tensioner. Timing chain seems tight only on compression stroke, and has quite a bit of slack between compression strokes on the cam gears. I can literally pick the chain up about a half an inch between the cam gears when not on the compression stroke. Should I dissassemble and look for stretched chain, worn gears and worn chain guides?
Oct 19, 2009 at 12:26 PM
MMPRINCE4000
  • 8,548 POSTS
Yes, I would replace chain, tensioner and guides, that is a lot of play. Inspect gear teeth for wear.
Oct 20, 2009 at 9:39 AM
